Tom's Hardware > Forum > Systems > Dell > Dell Inspiron 640m,Reinstalled Operating System,Still Having Problems
Forum Systems : Dell - Dell Inspiron 640m,Reinstalled Operating System,Still Having Problems
I have a Dell Inspiron 640m & i reinstalled my operating system,but when i log in to a user account it appears as if its in Safe Mode...but its not in Safe Mode...what does this mean and what should i do about this?? Is it something else that I need to install to get the account back to normal??
Sponsored Links
What OS do you have?
Are you saying that the user account setting is saying that it is in safe mode when you log in but that you continue on to complete the boot process and everything works like normal mode? And that this apparent error keeps repeating?
Have you done a cold boot - actually shutting down computer not just a restart to see if that clears it?
If not, one thing you might try is to use the F8 key on booting as you would to enter safe mode (see your manual). If that shows safe mode selected, you might change it.
While less likely to make a difference, you might also try unplugging the computer for about a minute then plugging in and booting - this is less likely to work but a lot easier to try then some other things.
If none of those work - you might try a system restore - assuming you have a recent restore point that will not take you back before some significant system changes.
Message edited by rockyjohn on 08-03-2009 at 10:26:08 PM
Reply to rockyjohn
It sounds like you didn't install your video drivers. That will make your resolution large similar to safe mode. You can check the device manager to verify the conflicts (yellow !)
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
If you haven't started checking yet - try Aford's suggestion before mine. I was still fumbling for more info to understand the problem but his diagnosis fits the symptoms as you reported them very nicely and is easy to check. Very wise.
Message edited by rockyjohn on 08-04-2009 at 08:33:44 PM
Reply to rockyjohn
Lol...Thanx rocky.....Tho, you put much more thought and elegance into your response :)
Reply to aford10
There are 1281 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
