Using US Power Strip in Europe
Hello-I wonder if you can use a US Power Strip (with a US to either British, or French plug adapter) in Europe. The power strips that I have say nothing about using them on 220v power. Thank you D Cooper
2 answers Last reply
More about using power strip europe
  1. Probably best not to. If the design or engineering of the US strip are marginal (e.g. Chinese) then it may not be safe on twice the voltage it was designed for.
    You can get socket adapters in Europe (and in the US presumably).
  2. Thank You, fihart--
    I also had that concern.
    dcooper9119
SLR Power Cameras
