Yes No
Ads
Tom's Hardware > Forum > Cell Phones & Smartphones > iPhone > [Solved] Iphone 4s battery issue
Forum Cell Phones & Smartphones : iPhone [Solved] Iphone 4s battery issue
Best answer from Maziar.
HI,
I am thinking to get an unlocked iphone 4s 16 or 32 GB soon.
But i heard the news that at Stand By time also, battery drains too much.
Is this true or just a rumor?
Iphone 4s is good to buy or i get an Android?
Please Help..!
Reply to rockxdude
Some people are experiencing it and some aren't.And it's said that Apple will fix it via a software update
Reply to Maziar
When will the fix will come out?
And is it possible to fix it via soft. update?
Reply to rockxdude
According to some websites,5.1 is supposed to fix the battery life issues(The first beta version of it is out now)
Reply to Maziar
Is that beta version is working?
Reply to rockxdude
Seems not! I've seen users reporting no change in battery life.
But the final build is coming out soon,that may change it
Reply to Maziar
ok, let me see..
Any idea when it will be released.?
I need to buy it soon...
Reply to rockxdude
Best answer
I've no idea when it'll be released but it should be out in this month.
And don't worry,if you want to buy it then go for it.Because if you have battery issues,you can take it to the apple store
Reply to Maziar
ok, let's see...
Thanks for help..:)
Reply to rockxdude
This topic has been closed by Maziar
------------------------------ The end is near...
Reply to Maziar
There are 1860 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What Phone should i get?
By jvdlcr125, 24 days ago:
If your looking for something in the Samsung Galaxy family I'd suggest that you go with...
Best offers
Top experts
