Right-click on the desktop and select "Properties." Select tab "Settings." Under the drop-down menu make sure that "Multiple Monitors" is selected. See if that helps any.
Well . . . my XP desktop Properties ==> Settings tab does not have a "Multiple Monitors" choice. The two checkbox options are "Use this device as the primary monitor" and ""Extend my Windows desktop onto this monitor."
Thanks for the suggestion, but Fn + F8 doesn't help
In comparing my problematic laptop with another laptop that works with an external monitor, I notice a difference that may be related to my external monitor problem. Need some advice as to whether it is or not.
Working laptop's two entries in the dropdown:
1. Plug and Play Monitor on Mobile Inter(R) 945GM Express Chipset Family
2. (Default Monitor) on Mobile Inter(R) 945GM Express Chipset Family
Problem laptop's two entries in the dropdown:
1. Plug and Play Monitor on Mobile Inter(R) 915GM Express Chipset Family
2. HP w1907 Wide LCD Monitor on Mobile Inter(R) 915GM Express Chipset Family
Is lack of the "(Default Monitor) on Mobile Inter(R) 915GM Express Chipset Family" entry something to be concerned about? My recollection is vague, but I think that entry used to be there. I probably did something to blow it away. How do I get it back?
not realy but it could help to download the latest chipset drivers and also the button shortcut softwares. these softwares tell the keyboard what each key should do.
when you chose extend it will light up the other one and you can drag files
to the other one, there should also be an option called "clone" which what ever
you see in the laptop you see in the external, also makesure the resolution is the same like 1280 by 1024 is usualy ideal.
