Need Help With Display Problems...
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.general (More info?)
A strange problem developed on my monitor immediately after the "Dish
Satellite" guy installed the Dish for us. While he was at my house he
asked me to turn-off my computer as he was going to have the Dish Box make a
connection with his office to download something via the phone line. As we
have dsl, I guess he felt there might be a problem leaving the computer on.
So I turned-off the computer, which I seldom do, and he attempted his
call-out which for some reason didn't work for him. As he was about to
leave, I re-booted my computer. The normal text I would see on the monitor
as it boots up looked like gobbledy-gook. Many of the words were there,
but some of the letters were spaced way-out. Presently, when I boot-up,
which I've done numerous times since yesterday, the main windows screen does
all kinds of strange things: vertical lines, cursor almost non existent and
frequently just a mere speck; often when moving the mouse a bit, the screen
goes black for a moment. strangely enough, when I go on the internet via
Internet Explorer, things seem to work okay, with some minor display
problems and black-outs.
I went out and bought another monitor, thinking that must have been the
problem, but it wasn't. Would the most likely culprit be a bad video-card?
That's all I could guess... Btw, I scanned my computer for any viruses
and/or spyware, and both scans turned-up nothing. I'm not sure if the Dish
guy had anything to do with my problem, or if it's just a mere coincidence.
I would appreciate any tips/advice with my display problems. Thanks in
advance.
advance.
More about : display problems
Hi Dave,
My first call would be to find out why his attempt call-out didn't work for
him. Second question, same call would be: Why did I have to turn my
computer off during this time? What would have been the ramifications if
not (if they know, even better) and if not then spurt out what has happened.
Take if from there and return your recently purchased merchandise until this
is all figured. Good luck with your new satellite and computer.
All the Best,
Kelly (MS-MVP)
Troubleshooting Windows XP
http://www.kellys-korner-xp.com
"Dave M." <nospam@nospam.com> wrote in message
news:zO0De.7951$NU2.7719@newssvr13.news.prodigy.com...
>a connection with his office to download something via the phone line. As
>we have dsl, I guess he felt there might be a problem leaving the computer
>on.
> monitor as it boots up looked like gobbledy-gook. Many of the words were
> there, but some of the letters were spaced way-out. Presently, when I
> boot-up, which I've done numerous times since yesterday, the main windows
> screen does all kinds of strange things: vertical lines, cursor almost
> non existent and frequently just a mere speck; often when moving the
> mouse a bit, the screen goes black for a moment. strangely enough, when I
> go on the internet via Internet Explorer, things seem to work okay, with
> some minor display problems and black-outs.
> video-card? That's all I could guess... Btw, I scanned my computer for
> any viruses and/or spyware, and both scans turned-up nothing. I'm not
> sure if the Dish guy had anything to do with my problem, or if it's just a
> mere coincidence. I would appreciate any tips/advice with my display
> problems. Thanks in advance.
Hi Dave,
All the Best,
Kelly (MS-MVP)
>on.
Hello Dave,
It looks like that this issue may be caused by the bad video-card or the
disturbance signal from the Satellite.
I agree with Kelly's suggestion that we should find out the effect from the
satellite at first.
Good luck.
Jacky Gu
Microsoft Online Partner Support
When responding to posts, please "Reply to Group" via your newsreader so
that others may learn and benefit from your issue.
Business-Critical Phone Support (BCPS) provides you with technical phone
support at no charge during critical LAN outages or "business down"
situations. This benefit is available 24 hours a day, 7 days a week to all
Microsoft technology partners in the United States and Canada.
This and other support options are available here:
BCPS:
https://partner.microsoft.com/US/technicalsupport/suppo...
Others: https://partner.microsoft.com/US/technicalsupport/suppo...
If you are outside the United States, please visit our International
Support page: http://support.microsoft.com/common/international.aspx
This posting is provided "AS IS" with no warranties, and confers no rights.
| References: <zO0De.7951$NU2.7719@newssvr13.news.prodigy.com>
| Subject: Re: Need Help With Display Problems...
| Date: Tue, 19 Jul 2005 01:28:13 -0500
| Lines: 51
| X-Priority: 3
| X-MSMail-Priority: Normal
| X-Newsreader: Microsoft Outlook Express 6.00.2900.2670
| X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2670
| X-RFC2646: Format=Flowed; Response
| Message-ID: <OfyzVsCjFHA.1148@TK2MSFTNGP12.phx.gbl>
| Newsgroups: microsoft.public.windowsxp.general
| NNTP-Posting-Host: cpe-68-206-186-167.sw.res.rr.com 68.206.186.167
| Path: TK2MSFTNGXA01.phx.gbl!TK2MSFTNGP08.phx.gbl!TK2MSFTNGP12.phx.gbl
| Xref: TK2MSFTNGXA01.phx.gbl microsoft.public.windowsxp.general:427389
| X-Tomcat-NG: microsoft.public.windowsxp.general
| Hi Dave,
for
happened.
this
| All the Best,
| Kelly (MS-MVP)
make
As
computer
| >on.
were
windows
when I
with
for
just a
Hello Dave,
satellite at first.
Good luck.
Jacky Gu
BCPS:
| Lines: 51
| X-Priority: 3
| Hi Dave,
for
happened.
this
| All the Best,
| Kelly (MS-MVP)
make
As
computer
| >on.
were
windows
when I
with
for
just a
Kelly & Jacky-
Thanks for your replies. I called Dish and they said that the phone call
the "box" makes for activation is simply a regular call to their office to
activate the account. He said it's a passive box that merely makes a
connection. He did not really know why the tech guy's call did not work
when he attempted to activate my box.
He also said the Satellite itself does not give off any magnetic fields or
otherwise adversely impact computer equipment.
So, would you conclude, knowing that the monitor is not the problem, that
the video card needs to be changed? Is there any other logical component
of my computer that could be causing this problem? Thanks very much for
any additional help.
>on.
Kelly & Jacky-
>on.
Related ressources
- Display problems need urgent help please - Forum
- Need Major help with Display problem - Forum
- Display problems ( Need Help Please) - Forum
- [ Problem ] display problems really need help - Forum
- Display Driver Keeps Crashing NEED HELP ! - Forum
since you say you turned the system off for the first time in a very long
time, I'd suspect that that power-cycle and/or thermal-cycle caused
something to "break". I'd suggest opening up your box, and cleaning it,
I'll bet it's dusty! reseat all cards, check all fans, etc. reseat all
connectors (you swapped monitors, so that connector was reseated).
If you're lucky you'll get it back. If not try a friend's video card (a
good friend!) to verify, and put your video card in their box to verify
that it is fried.
that it is fried.
My computer has been turned-off as recently as a week ago. So, it's not
like I haven't had if off in a long time. But I'll take your advice and
clean-out the cpu and try to re-seat everything...
Is there any chance that my Windows XP could be causing any of these
problems? Most of the weird display problems show-up on my desktop.
Although, in any program, including Windows Explorer or Outlook Express the
screen will occasionally go black; then I just move the mouse or enter a
key and it goes back on. Weird, huh??? Should I try to re-install XP?
Or is this not likely the cause? Thanks again.
<frodo@theshire.org> wrote in message
news:11dqdhrp3as0afe@corp.supernews.com...
> that it is fried.
> that it is fried.
Hello Dave,
In my opinion, this issue does not seem to be related to Windows XP. It
should be caused by the hardware. You may change a video card as a test.
Jacky Gu
BCPS:
<11dqdhrp3as0afe@corp.supernews.com>
| Lines: 27
| X-Priority: 3
| X-Newsreader: Microsoft Outlook Express 6.00.2900.2180
| X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2180
| X-RFC2646: Format=Flowed; Original
| Message-ID: <MTaDe.4788$_%4.4521@newssvr14.news.prodigy.com>
| NNTP-Posting-Host: 67.121.78.107
| X-Complaints-To: abuse@prodigy.net
| X-Trace: newssvr14.news.prodigy.com 1121794668 ST000 67.121.78.107 (Tue,
19 Jul 2005 13:37:48 EDT)
| NNTP-Posting-Date: Tue, 19 Jul 2005 13:37:48 EDT
| Organization: SBC http://yahoo.sbc.com
| X-UserInfo1:
F[OGB_KEWB^UCWDYIBHZOWP@YZOZ@GXOXZ\@LWQHBATBTSUBYFWEAE[YJLYPIWKHTFCMZKVMB^[Z
^DOBRVVMOSPFHNSYXVDIE@X\BUC@GTSX@DL^GKFFHQCCE\G[JJBMYDYIJCZM@AY]GNGPJD]YNNW\
GSX^GSCKHA[]@CCB\[@LATPD\L@J\\PF]VR[QPJN
| Date: Tue, 19 Jul 2005 17:37:48 GMT
| Path:
TK2MSFTNGXA01.phx.gbl!TK2MSFTNGP08.phx.gbl!newsfeed00.sul.t-online.de!t-onli
ne.de!border2.nntp.dca.giganews.com!nntp.giganews.com!newscon06.news.prodigy
com!prodigy.net!newsmst01b.news.prodigy.com!prodigy.com!postmaster.news.pro
digy.com!newssvr14.news.prodigy.com.POSTED!efe31f9c!not-for-mail
| Xref: TK2MSFTNGXA01.phx.gbl microsoft.public.windowsxp.general:427728
the
long
| > that it is fried.
Hello Dave,
Jacky Gu
BCPS:
| Lines: 27
| X-Priority: 3
| X-UserInfo1:
| Path:
the
long
| > that it is fried.
Thanks Jacky once again for your input.
Funny enough, things have almost returned to "normal" without me doing
anything more. Initially I re-seated the video card and vacuumed out the
dust on that card; but even after doing that, some of the symptoms had
persisted. Well now, about 3 days later and things are looking almost
perfect once again. Occasionally, I'll see a line from an internet news
article "misaligned", but other than that I'm feeling pretty good.
I have no clue what caused the weird display problems. I'm assuming that
the "Dish" was not responsible, but it was sure coincidental that the
problems fell right on the heels of them doing their install and me
rebooting my computer.
Thanks once again for everyone's kind recommendations! I really appreciate
your help.
"Jacky Gu [MSFT]" <v-jackyg@online.microsoft.com> wrote in message
news:Qh4xeBPjFHA.3472@TK2MSFTNGXA01.phx.gbl...
> Hello Dave,
> Jacky Gu
> BCPS:
> rights.
> | From: "Dave M." <nospam@nospam.com>
> | Lines: 27
> | X-Priority: 3
> | X-UserInfo1:
> | Path:
> .com!prodigy.net!newsmst01b.news.prodigy.com!prodigy.com!postmaster.news.pro
> not
> the
> a
> XP?
> long
> it,
> all
> (a
> verify
> | > that it is fried.
your help.
> Hello Dave,
> Jacky Gu
> BCPS:
> rights.
> | Lines: 27
> | X-Priority: 3
> | X-UserInfo1:
> | Path:
> not
> the
> a
> XP?
> long
> it,
> all
> (a
> verify
> | > that it is fried.
Related ressources:
- ForumDual monitor display problem - I need your help !
- ForumDisplay Drivers Crashed, ( need help ).
- ForumNeed help for tripple screen display
- ForumHELP , Medion laptop display problems
- ForumNeed help with Display port issue.
- ForumNeed Help ! Lights Turn on all fans run but no display
- ForumHelp ! Bad display problem when gaming
- ForumDisplay issue need help
- ForumRadeon HD 6850 Display Problems ! HELP !
- ForumNo Display Need Help VGA to DVI!
- ForumHelp ! Display problems on BenQ Joybook u101 (Win7)
- ForumHi to all need help for mother board no display problem
- ForumPCMCIA slots need more power??? HELP!
- ForumNeed help tracking hours
- ForumWindows Explorer Encounters problems, OCA says its Purstiu.A
- More resources
Read discussions in other Windows XP categories
