Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Grey "bleeding" pixels problem
Forum Computer Peripherals : Flat Panels/ LCDs - Grey "bleeding" pixels problem
I have some "dead" pixels (bunched together in two different spots) on my monitor, although they don't really appear to be dead per say. On a white background, under a magnifying glass, they look like they're bleeding, only half or so of the pixels are grey and the rest are white.
This monitor is only a few months old. Can someone tell me what's wrong?
Sponsored Links
It could be a stuck sub pixel, but then it would look cyan, yellow, or magenta, not gray.
If it's a TN panel a stuck pixel will be bright, on an MVA or IPS a stuck pixel will be dark.
Make sure the monitor is clean. It could be a speck of dust on the inside (I had this happen once), try tapping the monitor gently, or spraying some compressed air inside, but don't over do it.
------------------------------ 6510 8-bit CPU @ 1.023 MHz
64Kb RAM 20Kb ROM
VIC II
SID
Reply to MagicPants
It's definitely not dirt on the screen itself, but I guess it could be on the inside. The room it's in is very dusty, no matter how clean I try to keep it. Thanks for the tip.
Reply to caledfwlch
There are 959 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
