Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Sony GDM-W900 diagonal line problem
Forum Computer Peripherals : CRT Monitors - Sony GDM-W900 diagonal line problem
I've just bought a second-hand Sony GDM-W900 24" CRT computer monitor and it's great apart from 3 very thin lines (red, green and blue) which run at about a 4 degree angle downwards from right to left then continue horizontally from left to right (but much fainter), in the bottom third of the screen. They are there at all resolutions and I have tried adjusting every setting in the menu to no avail.
I know about the damper wires but I've seen those. These are about the same thickness but at a slight angle and coloured. I found out how to do a monitor self-test (with no leads) and the lines are there. With no input they flicker up and down the screen so it's nothing to do with the input but a monitor fault unfortunately. I've also tried tapping the screen, degaussing etc.
Is there any hope?
Sponsored Links
There are 1386 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 20:19 israil won the Sophmore badge
  • 01:00 Ishaan won the Uniformed badge
  • 01:00 nofun won the Uniformed badge
  • 01:00 ElMoIsEviL won the Spy badge
  • 01:00 mparham won the Freshman badge
  • 01:00 ishaan won the Freshman badge
  • 01:00 Mario097 won the Uniformed badge
  • 01:00 timobkg won the Freshman badge
  • 01:00 ethr won the Freshman badge
  • 01:00 amirp won the Freshman badge
