DELL XPS 1640 Heat Problems
Forum Laptops & Notebooks : General Laptops & Notebooks - DELL XPS 1640 Heat Problems
Having some heat problems with my XPS 1640 and the heat it's putting out.
When I have been using it for up to an hour, the heat gets unbearable to touch underneath, however it is fine to type and whatever, just underneath it is extremely hot to touch.
It gets a lot hotter whilst charging, and here is a screenshot of the temperatures whilst it has been on for a while and whilst charging:
http://i28.tinypic.com/2vw5l4p.jpg
Are these temperatures okay? What is the max temperature before I should start worrying? What can I do to help keep them down?
Thanks a lot.
Sponsored Links
They are warm, but not bad. With laptop CPUs you don't have to start worrying until about 90*C and theses systems are designed to throttle and shut down at certain points before they cause damage to either the CPU or the rest of the system.
1)How old is the system? You may need to blast the dust out of the fan intakes which is simply done with a $10 can of compressed air. Dust is a laptops worst enemy.
2)Make sure all of the system fans are actually running. Put you have behind the exhaust ports and make sure there is actually air flowing. If not, one of your system fans may have died.
3) All else fails you can pick up a laptop cooling pad: http://www.newegg.com/Product/Prod [...] rchInDesc=
Reply to lostandwandering
- 0 +
its okay realy, just for the safety of your legs get a laptop cooler board which is a board with a fan on it and you put it underneath the laptop. ebay £10
Reply to pcfixed
I've had it for a week or two now and all the fans are working fine to my knowledge.
I may look into the cooling board, thanks for the suggestion.
Just wanted to make sure that this heat is fine. When you say warm though, it's not warm to the touch, it's bloody boiling underneath!
Reply to crumble114
well if you feeling up to it strip your laptop an replace all the thermal paste i have the xps 1530 and just doing that dropped my temps by 8c at load
Message edited by obsidian86 on 09-02-2009 at 07:14:46 PM
Reply to obsidian86
When you say you don't have to worry about temps until it hits around 90, which reading is that for?
Reply to crumble114
The CPU. Specifically where it says "Core#0 and Core#1". Once you get to that point, safety measures that are built in will reduce the CPU's speed in a first attempt to prevent overheating and damage. If the temps continue to rise, the laptop will shut off.
Okay thanks a lot for the help.
Going to look into a 'cooling pad' or something similar, could someone link me to a decently priced cooling method for my laptop?
Thanks.
Reply to crumble114
This one seems decent: http://www.newegg.com/Product/Prod [...] 6834997420 . Plus Cooler Master is a good company for cases. Otherwise I would look for something with at least 2 decent sized fans. The smaller the fans are, the noisier it's going to be.
- 0 +
its just a peace of plastic with fans on it, any brand is smart enough to make one, i use a cheap chinese one which lasted 2 years and still works
whats important is get one where its fans are near your laptops air vents, there is no point for a cooler board that has a fan in the middle and you dont have
at least 1 air vent in the middle.
online is not the way, i think taking your laptop to a shop and just making sure it feels okay and its situated properly is the way.
your laptop heats a lot for your hands but dont worry that's fine, if you use the laptop and block the air vent (jeans, pillow, bed cover) it heats up like that
leave it on a flat table and it will be better.
------------------------------ http://www.youtube.com/reply4reply
Reply to pcfixed
I've had the 1640 for about two weeks now, and I definitely know what you mean. Although the temperatures at the core aren't very high compared to some other laptops (some stressed cpus can reach almost 90 degrees C!)(Some Examples), it's bothersome to have the keypad flare up or the fan to blast every couple of minutes, not to mention the temperature of the metal rim on this thing :ouch: . Forget cooling pads, and forget thermal paste. There's nothing wrong with the hardware of this machine except that Intel uses standard voltages for all their motherboards, and this one it's especially high.
I've found that undervolting (Explanation) has decreased the temperature of my 1640 to the point where I idle at about 36 degrees Celsius and Full load (for 30 minutes) at about 57 degrees. In fact, I'm stress testing right now and hovering at 55 degrees. Not once has the fan kicked into overdrive, nor do the changes I made sacrifice performance or reliability (if done correctly).
If you're interested in lowering the temperature of this beast (and increasing battery life as a bonus), try Undervolting your 1640. I've had it set this way for a week now, and it has not in the least compromised my experience with this laptop. World of Warcraft still hovers at a good 30 fps on medium-high graphics settings, but now the lappy doesn't throttle down when I play for more than 20 minutes :sol: .
FlipFire created the best tutorial on learning how to undervolt http://forum.notebookreview.com/showthread.php?t=235824. Even for amateurs it's a pretty good guide. Read the thread, and get an idea of what it's all about and if you want to try it. Undervolting, unlike overclocking, is very safe and doesn't hurt your hardware or performance. I've dialed down my settings pretty well, and haven't had a single crash or BSOD. My settings are listed here if you want to use the same ones:
http://i119.photobucket.com/albums/o136/lefthandedspatula/1.jpg
http://i119.photobucket.com/albums/o136/lefthandedspatula/2.jpg
Troubleshooting:
If you can't get all the voltages listed, try this, it's from DarkSilver's post on http://forum.notebookreview.com/showthread.php?t=393073
Quote :
"Go to your RMClock folder. Find RMClock_Tweaks. It is a Registration Entries file.
Apply it. (Double-click it)
Solution/Steps:
1.) Enter regedit(registry editor, click Start button, type in regedit and press enter).
2.) Find [HKEY_CURRENT_USER\Software\RightMark\RMClock]
3.) Ok! Now, find UnlockEIST, IntelPMP4.EIST, UnlockFid, UnlockVid and UnlockTM2 to value 1. Basically, the original value is 0.
4.) Restart your computer and have fun. Make sure your RMclock is turn-on(can set the RMClock to start automatically for every boot-up), if not, it won't work."
Also
, if you can't get RMClock to work due to an unsigned driver, you can find the signed driver at
RMClock DL
I don't like Rapidshare, but it's the only option if you want to download without registering to a forum. Search around if you're not comfortable, there are other links to this driver, but this is the one that I used.
I really really really hope this helps, if you're willing to spend an hour or two getting your 1640 in tip top shape. It's a great machine, and it's a shame that the board is so overpowered that it produces all that heat. As for the fan design, I think Dell chose that location because it's worked for Apple for so long with their Macbook series. It's a fantastic machine and I wouldn't trade it for anything else. I hope that after you fix this issue (Dell may take a long time for release of an update), you love the 1640 as much as I do. Cheers!
P.S. - Don't forget to upgrade your bios to A11! This will certainly help with some of the heating issues! Dell Support for 1640
Reply to alecazam
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > DELL XPS 1640 Heat Problems
There are 775 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
