hi all, i have an HP DV1600 Series laptop, i am having issues with the sound not comming out of the built in speakers, audio drivers are correct and updated, headphone jacks work fine, the only time i get audio out the speakers is for a split second when i unplug the headphones, and sometimes at random 1 or both work for a few minutes, i know the speakers work cause i get sound for a second, i know drivers are fine cause i get sound from jacks anytime i need, please help!
------------------------------HP DV1659US Notebook, Core Duo mobile T2450, 2GB DDR2 667 PC2-5300 RAM, DVD Burner, 14.1in Widescreen, GMA945, Windows 7 Ultimate 32 Bit RC 7100, 100GB SATA HDD 20/80, Wireless a/b/g, 3 USB 2.0, 1 Firewire, HP Remote
the headphone socket might be damaged, because speakers get muted when you insert headphones, so now your speakers beleive there are headphone plugged even they're not.
ya that looks like a posability, how would i go about confirming that? is there a sensor within the jack i can disable? or any other way to fix it?
but if that is the case, why do they work at random, even when i dont touch or play with jacks?
Message edited by furious_cruzer on 09-03-2009 at 07:21:33 PM
Reply to furious_cruzer
that's the thing, its risky if I was you i'd open the laptop apart and desolder the phone jack and see if the speakers work thatway.
there is no sensor or anything its just current cut, when the headphones are plugged the current stops from going towards speakers
well i dont think its the jacks, cause even my mic doesnt work, im thinking its a sound card problem, is there a certin chip or something i can replace? its intagrated to the mother board. or am i looking more at replacing the motherboard?
