Tom's Hardware > Forum > Home Theatre > Digital TV > Can you convert basic cable to digital cable by using a vcr/dvd combo
Forum Home Theatre : Digital TV - Can you convert basic cable to digital cable by using a vcr/dvd combo
Hello Everyone,
I had just purchased a 19" Phillips LCD TV 720p. The TV is nice, but the problem is that i do not have digital cable with a box. I just have regular cable which only uses the coaxial cable that plugs into the tv. My question is can i use a VCR/DVD combo to connect to the tv with component cables to try and make the picture come in more clear? Right now its alright, but only being displayed at 480i. Any suggestions would be great...
Thanks,
Sponsored Links
AFAIK, since you're still receiving an analog signal, no matter how you try converting the signal through whatever device, you'll still end up with output that doesn't maximize your LCD TV.
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
There are 1267 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
