Hello,
Im trying to change my galagas power supply to a switching power supply and am not sure how to hook it up its a 12A 115V WITH +12V2A -5V1A +5A12A outputs can you help thanks Bobby
Connections should all be the same as in the old power supply, note how it's hooked up now, do the same thing with the new power supply. Take pictures of the connections if you need.
