Maybe, but it won't work very well. The best I can think of is there are a few monitors with usb connectors instead of vga/dvi/hdmi. These are intended for use as secondary monitors and are really slow.
Then maybe you could find wireless usb. It might work technically, but you'd be far better off just buying a small computer or laptop.
I guess what I'm saying is it might work in an interesting/curiosity sort of way but it's not going to work in a useable/non-crashing sort of way.
Also it'll probably give you cancer.
------------------------------6510 8-bit CPU @ 1.023 MHz
64Kb RAM 20Kb ROM
VIC II
SID
Reply to MagicPants
