I have recently bought a Gateway NV58 15.6" laptop and I have noticed that, for no good reason, the touch-sensitive volume adjust buttons, while they do adjust the volume, no longer cause a small pop-up (similar to that of macs) where it shows the volume in a bar made up of small blocks (if @ were blocks, it would be @@@@@@@@@@@@@@@).
Also, the mute button light no longer turns on when its muted, even though it does still trigger the mute.
Your expertise are always appreciated, thanks.
I have a gateway labtop that does the same thing the touch sensitive volume control above the keys is whacked to say the least. does anyone have any idea how to disable those touch keys.
I have a NV52 and the touch buttons are working but the lights for the mute button are not working. also it doesn't pop up on the screen what I did. why is this happening? how do I fix this? do I use the same thing?
Dude me 2, except my mute light is always on, but still umutes and mutes. and the "P" button doesn't respond or open google chrome (my selected program to work when pressed)
Okay with some leg work of my own (not of gateways support, there answer was to restore to factory condition) of coarse that will work. But I knew there had to be an easier more timely way of fixing this problem. So after the same problem came back I decided to look deeper into the problem knowing that gateway wasn't going to help. I found that the program that controls the function of the touch buttons.
So my solution is simple and here is a small how to:
Run the Gateway Recovery Management,
click okay at the prompt,
click "Restore" (Top Left),
click "Reinstall Drivers or Applications",
select "Contents",
Scroll down to "Launch Management" Application and
click the install icon to the right.
Once Installation is complete restart your computer and login.
Your touch buttons should now work.
I hope this works for all of you as it did for me.
Using the Launch Management driver did make the display appear on the monitor again, but there is still no audio (volume) from the speakers or output from the headphone jack.
The Launch Management fix is just for the buttons to work again. For your audio problem try using the Gateway "Recovery Management" described above but instead of reinstalling the "Launch Management" select the audio driver :Conexant Audio CX20561-152"
Do that, restart and post back if it works or not and we can go from there.
Thanks for responding Crazy Timmy. I did re-stalled the Conexant Audio CX20561-152 but that didn't fix the problem.
But after searching on the net someone pointed out the problem. It's amazing how simple the problem was to fix.
I went to the Control Panel then went to the "Sound" icon. In the Playback tab there are two playback devices. The "SPDIF Interface" and the "Speakers." I had to right click on the "Speakers" playback device and selected it as the Default Device. Click apply then OK. Back to normal.
Some how after loading software it changed Default Devices from the "Speakers" to the "SPDIF Interface." Live and learn!
