Tom's Hardware > Forum > Audio > Audio Technology > Am I able to get Surround Sound with these specs?
Forum Audio : Audio Technology - Am I able to get Surround Sound with these specs?
Ok, I want to get 5.1 sound on my sons PC.
My equipment is this:
"STV Digital 6" Surround sound system
3D Premium Onboard Surround Sound soundcard
The STV has only 1 RCA (1 red, 1 white) audio output (and a headphone jack)
The soundcard has Green, Pink and Blue outputs.
I have tried using an RCA>Stereo converter between the STV and PC, but I can only get either Front, Rear or Sub/Centre channels at one time (ie, only 2 speakers at a time)
I have scoured the net looking for solutions, and can't find what I'm looking for...
So, is there a way for me to split the RCA outputs into 3 channels (ie, a red/white at one end, and 3 stereo jacks at the other), or do I need a new soundcard or surround system!?
Thanks in advance
Sponsored Links
Spliting the signal is not going to make a 5.1, you will get stereo on 6 speakers. Check if your sound manager can setup to 5.1? If you can, then you'll need 3 mini jack to RCA cord to connect it to a surround amplifier input or to 5.1 speakers.
Reply to rexter
- 0 +
Thanks for the reply. Yes, the sound manager can handle 5.1.
Could you point me to a site that sells 3 mini jacks -> RCA please? I searched for such a cable before I posted here, but couldnt find it.
Really appreciate it!
Reply to Euryon
I can't find any info on the STV surround sound but if it doesn't have a 5.1 channel discrete input you won't have anyplace to connect the output of your card to. If if has a digital input and your audio card will output SPDIF digital audio then go that way. If the STV doesn't have digital inputs then just use the front stereo outs from the audio card (set the output to 2 channel) and let the Dolby ProLogic processing in the STV create the surround.
Reply to americanaudiophile
There are 1148 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
