Sign-in / Sign-up
Ps3 sound problems
  • PlayStation
  • Games
  • DVD
Last response: in Other Consumer Electronics
February 2, 2010 10:23:33 PM
Hello,
when i first start a game or a dvd on my ps3 the sound will fade in and takes about 5 sec. is this normal?
More about : ps3 sound problems
February 4, 2010 12:04:15 AM
Are you using an audio receiver? How are you connecting your PS3 to your TV/Receiver?
I would say make sure all your connections are secure, check to make sure your HDMI cable isnt bent or anything. If you using optical make sure the cable is in all the way. Then last (if your using a audio receiver) make sure your settings are all correct according with your PS3.
I have a audio receiver that wont make sound until it detects sound, and when there is no sound going in, it sorta goes on a standby. For instance, when I had the menu "clicks" on my PS3, I would only hear about half of them because of my receiver was going on and off. Maybe you have a similar problem?
Hope this helps.
m
l
