Tom's Hardware > Forum > Audio > Audio Technology > Sound doesnt work
Sound doesnt work
Forum Audio : Audio Technology - Sound doesnt work
So I built my computer and when i decided to change cases my power supply blew. So after I got a new PSU and checked if everything was plugged in. It all was, so I turned it on. Then all the sudden a loud squealing noise started. So i checked everything, the video card had the power connected and RAM was seated correctly. Turned it on again and heard the same noise. So then i diagnostically started unplugging certain components and plugs in the motherboard and came to find out it was when i plugged in the front audio ports that i heard the noise. Computer works fine, except that sound wont work at all.
I don't have a sound card, Just on board. I updated all the drivers. and sound appears to be going through on the volume control, but nothing comes out of the speakers. I also tried multiple speakers and even headphones. Checked all my programs to see if sound was muted but none say that it is.
Does anyone know what the problem is?
Sponsored Links
There are 1334 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
