Tom's Hardware > Forum > Storage > Hard Disks > Raptor Raid 0 speed issue
Forum Storage : Hard Disks - Raptor Raid 0 speed issue
I just recently installed 2x74gb raptors in raid 0
i have a soltek sl-75frn2 with built in raid controller its a promise fastrak 376 controller
the problem (if there is one) is that it flatlines at 110mb/sec (see pic) ive tested a single raptor and got 65-85mb/sec and was expecting 125mb+ with raid 0
<A HREF="http://storage.msn.com/x1pqUZNW2UDxSB4PMa0N0-ysn6wTFt7qW3IPrYvYseGbi2aixyweVSmZyfhwI3IXI_oBRE36R6AoMacwLSA1tYB-MWVAMDdwZQO4GewpKj35Tk" target="_new"> pic </A>
does anyone have any idea of why there seems to be a limit or bottleneck at 110mb??????????????????
it cant be the drives cos thers next to no peak or troughs as i would expect at start of drive then tailing off, it does drop near end of drive
now dont get me wrong im perfectly happy loading win xp with all programs antivirus and many other things it does when loading in only 10-15 secs (it was ONLY 5 secs with a fresh install of xp!!)
but if im missing out on 15-20mb a sec i wanna know why :)
Sponsored Links
That is pretty darn good. There are other factors that play in to performane overhead that is causing this. And you never get double performance, but you are getting good scores.
<pre><font color=red>°¤o,¸¸¸,o¤°`°¤o \\// o¤°`°¤o,¸¸¸,o¤°
And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
Reply to RichPLS
- 0 +
<i>>does anyone have any idea of why there seems to be a limit or bottleneck at 110mb</i>
Yep, that's the limit of the 33MHz 32bit PCI-bus (33e6*32=1.056Gb/s = 132MB/s). You need a wider/faster bus if you want more speed.
Reply to sjonnie
- 0 +
AAAAAAAAAAAAaAHHHHHHHHHHHHHHHHHHH thank you guys for the replies
that explains everything
never thought it would be on the same bus
looking forward to an upgrade to PCIe when a wider choice of mobos come available
which leads me to wonder how a set of 6800 gt in SLI would effect my raid with a 939pin mobo would they be sharing bus bandwidth again?
Reply to MMUK
I get 112 MB/sec on my 2x74GB Raptor RAID 0 array. That is all I can get, so you are fine. We are just maxed out on the PCI bus. I am using the SI 3112 on my Asus A7N8X Deluxe. I always wondered how much faster these drives could go, if they weren't bottlenecked. Anyways, only route is PCI express that runs at 66 Mhz or 133 Mhz instead of 33 Mhz.
My System:
<A HREF="http://amdgamingrig.dyndns.org" target="_new">http://amdgamingrig.dyndns.org</A>
Reply to davemar14
- 0 +
<i>> looking forward to an upgrade to PCIe</i>
There is already a PCI technology with increased bandwidth. The standards PCI slot is 32bit, 33MHz. This has been increased to 64bit, 66MHz although more advanced PCI-X slots are now 64bit, 133MHz. Boards carrying it are usually server boards though so PCIe is probably the best solution for desktops.
Reply to sjonnie
- 0 +
http://uk.asus.com/products4.aspx? [...] odelmenu=1
the asus A8N-SLI deluxe looks like a nice upgrade
twin 1 gb lan
3gb/s sata2 8 sata sockets i think
Reply to MMUK
- 0 +
damn its got some good features
i heard the new winchester 90nm amd64 were good overclockers too:(
at least my raptors be happy
<P ID="edit"><FONT SIZE=-1><EM>Edited by mmuk on 05/13/05 03:35 AM.</EM></FONT></P>
Reply to MMUK
- 0 +
AMD64 4800+X2 looks a tasty choice hope they manage Q3 supplies as promised
Reply to MMUK
There are 639 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
