Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Chkdsk at startup not solving hard disk problem
Forum Windows XP : Windows XP General Discussion - Chkdsk at startup not solving hard disk problem
Archived from groups: microsoft.public.windowsxp.general (More info?)
Even after scheduling `Chkdsk C: /f /r /v' to run in the system startup, the
'errors in the Volume bit map' comes back. The Startup Chkdsk clears the
error but after booting something creates the error again. I am using Norton
Disk Doctor for the Disk checking.
My System 1Mhz, 256mb Ram,WindowsXP Pro SP2, ZoneAlarm Free version
5.5.094.000, Perfect Disk Defragmenter version 7 etc. Even without running
the PD defragmenter to re-arrange files error appears. Any solution to clear
this error?
Thanks for any help & replies.
Brother Brock
Hare Rama, Hare Rama, Rama Rama, Hare Hare.
Hare Krishna, Hare Krishna, Krishna Krishna, Hare Hare.
Sponsored Links
It could be an idea to download, from the manufacturer of your harddisk (
maxtor or western digital for example ), the diagnostic utility to check the
harddisk. These utilities sometimes allow you to repair aswell or do a low
level format.
Keep in mind though to backup essential data before executing any task from
within those utilities.
The quicker you do the test, the better ( meaning if harddisk has
non-repairable errors you maybe still could use warranty ).
Maxtor's utility needs to be booted up from cd or floppy , assume that
applies to other utilities aswell...
greets Johan
"Brother Brock" <Nobodyknows@unknown.com> wrote in message
news:eKCtl7VjFHA.3540@TK2MSFTNGP14.phx.gbl...
> the
> Norton
> clear
> this error?
> Brother Brock
Reply to Anonymous
Possible Solution: Boot off your Windows XP CD-ROM, enter Recovery Console,
at Command, execute the following command.
chkdsk /p
exit
See if that helped.
Reply to Anonymous
> this error?
> Brother Brock
Do CHKDSK /F twice without using NDD between. If there are no errors
reported by CHKDSK the 2nd time then the problem is with NDD.
Steve
Reply to Anonymous
Thanks. Good sujjession. Gonna try that.
Brother Brock
Reply to Anonymous
NDD (as of 2003) is just a GUI shell for the chkdsk command, and not a
very good one; if often mis-parses the chkdsk messages and reports an
error that is not real (especially in the security descriptors section it
seems). So, don't trust it.
Reply to frodo
There are 487 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
