Imb thinkpad indow problem
Forum Laptops & Notebooks : General Laptops & Notebooks - Imb thinkpad indow problem
My IMB thinpad laptop cant go to windows. i pressed the blue access ibm and t cant fix the problem but i get this File SETUPREG.HIV could not be load The error code is 4096. what should i do?
Sponsored Links
Hi just a few things need to know is this a new hhd you are using have you changed the hhd on what the code means is you will have to reformat hhd and reinstall but before you do this i would like some moor info was it working ok before have you just installed and this is the problem there can be al sorts of problems why it wont boot but at the end off the day it ends up reinstalling what os are you using /vista/xp
Reply to bry
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Imb thinkpad indow problem
There are 1229 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
