Tom's Hardware > Forum > Audio > Audio Technology > Making a 7.2 Sound System with z-2300 (2.1) and z-5500 (5.1)
Forum Audio : Audio Technology - Making a 7.2 Sound System with z-2300 (2.1) and z-5500 (5.1)
Hey
I was wondering if it is feasible to hook these two system up on a Sound Blaster Fatal1ty PCI-E sound Card. If so, how (which cables are best, ect)
Sponsored Links
groovinggoblin wrote :
Hey
You need adapters as creative sound blaster audio card have a way of connecting surround anything higher than 5.1 systems or have somebody or make your own connections for the sound card. check 7.1and this is how that thing look like
http://support.creative.com/kb/Sho [...] x?sid=3069
http://www.tigerdirect.com/applica [...] &CatId=466
Use the Z-2300 for the front and the Z-5500 for the rest of the channels.
If your option is to purchase the cable for 7.1 (links above) then buy the 3X (female RCA to mini-jack female socket) for Center/Sub, sides & rears. The front channel can be directly plugged on the soundcard.
http://www.amazon.com/RCA-Female-3 [...] B000I98ZM8 connects 3 of these to the http://support.creative.com/kb/Sho [...] x?sid=3069 then to Z5500. Pair #1 sub and center, #2 sides and #3 rear.
Reply to rexter
Thanks!.....and the second option would make a full 7.2 surround sound?
Message edited by groovinggoblin on 04-23-2009 at 12:16:40 AM
Reply to groovinggoblin
- 0 +
Just to clear things up.
Option 1 - is to get someone to make the conversion for you
or do it yourself which might cost alot less than option 2
Option 2 - you need 3 of this unit -> http://www.amazon.com/RCA-Female-3 [...] B000I98ZM8
and 1 of this unit -> http://support.creative.com/kb/Sho [...] x?sid=3069
Both will get you 7.2
Message edited by rexter on 04-23-2009 at 06:03:54 AM
Reply to rexter
- 0 +
Hello rexter, i previously purchased a z-5500 system and have the opportunity to buy a second one from a friend of mine. my question is:
I have a normal laptop with a realtek high definition audio card an recently bought a Creative X-Fi Notebook Sound Card with wireless receiver.
what are my possibilities to connect them together? and still have a good sound ?
thanks
with kind regards Tjtyson :)
Reply to tjtyson
- 0 +
Check your manual if Creative X-Fi Notebook Sound Card is capable of SPDIF output, use 3.5 mm to RCA cord to connect analog or digital connection.
Reply to rexter
7.2? thats mad
man that would be a quality setup
Reply to Anonymous
There are 993 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 14:45 trinix won the Sophmore badge
  • 01:00 citywill won the Uniformed badge
  • 01:00 Tameas won the Uniformed badge
  • 01:00 themeanmachine won the Uniformed badge
  • 01:00 taavi won the Uniformed badge
  • 01:00 mikrouwel won the Uniformed badge
  • 01:00 noiz won the Uniformed badge
  • 01:00 herojig won the Uniformed badge
  • 01:00 mrcmark won the Freshman badge
  • 14:09 pauldh won the Sophmore badge
