Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Need Help: Which laptop do should i choose
Forum Laptops & Notebooks : General Laptops & Notebooks - Need Help: Which laptop do should i choose
Dell XPS 16
Processor-Intel® Core™ 2 Duo T9600 (6MB cache/2.8GHz/1066Mhz FSB)
RAM-4GB Dual Channel DDR3 SDRAM at 1067MHz (2 Dimms)
1920 by 1080 screen
Video Card ATI Mobility RADEON™ HD 4670 – 1GB
Hard Drive 500GB 7200 RPM SATA Hard Drive
Final cost around $1600
or
Sager NP8662
Processor- Intel Core 2 Duo Processor P8700 / 3MB L2 Cache, 2.53GHz, 1066MHz FSB
RAM-4GB Dual Channel DDR3 SDRAM at 1066MHz - 2 X 2GB
1680 by 1050 Screen
Video Card-Nvidia GeForce GTX 260M Graphics with 1GB DDR3 Video Memory
320GB 7200rpm SATA 300 Hard Drive
Final Cost- 1500
Wondering which one would be better for gaming,Im hoping these will run Call of Duty and Fallout 3 . My budget is 1500-1600 so i can't upgrade much of the initial NP8662
TY for any help
Sponsored Links
The Sager is the better choice for gaming. The GTX260M is a better card than the HD4670 and will run both COD and Fallout 3 (The Sager in my sig can run COD 4). The Sager is also cheaper to boot and the difference between the CPU's isn't so large that you will notice.
------------------------------ LAPTOP: Sager NP5760|T7200|2gb DDR2-667| 100gb 7200rpm HDD| 512mb 7950GTX|17'' WUXGA
Desktop: Core2 E7200 | Corsair 2gb DDR2-800 | Gigabyte EP35-DS3L | 250gb Seagate Barracuda | MSI GTX260 (192 SP) | Corsair VX550 | Antec 300 case
Reply to lostandwandering
When you say run, does that mean just basic on low settings, or that it will run smooth on medium or higher?
Reply to tennisguru72
For me? It runs at medium settings, but at a lower resolution. But I don't think you were asking about that :D
For the GTX260, playable at medium to high settings: http://www.notebookcheck.net/NVIDI [...] 559.0.html
last question on the Sager, if i had $ to upgrade, is it worth putting money into the procesor/system storage space, or will the base NP8662 work?
I think I would put the money into the CPU for longevity sake. HDD's are easy to find and upgrade even if it's just an external unit. CPUs aren't as easy to find. Intel is also releasing new processors which will make yours even harder to find.
There are 1058 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
