Advice on this system.
Hi all. Sadly, my only option is to buy a pre-built system from a UK company that sells PCs.
What do you think of this PC? The PC will basically be used for gaming.
**If everything is good enough with it, I hope to upgrade the GPU; and PSU if needed.**
http://www.comet.co.uk/shopcomet/product/602612/PACKARD-BELL-IMEDIA-A3520UK
What are you overall thoughts (excluding the GPU)?
Will I be able to upgrade the GPU (and PSU if needed) from its current one to a 4850, for example?
Thanks, much appreciated.
2 answers Last reply
More about advice system
  1. Hi men, the link doesn't work.
  2. Ah ok, sorry. Nevermind now. Thanks anyway.
Packard Bell GPUs PCS Gaming Computers
