Infocus SP61MD10 No Power
I have a Infocus SP61MD10, The Menu, Chanel, and Volume light is lit solid blue but the unit will not power on, even with the remote nothing. I heard it might be the control board? any help would be great.
Thanks Tony
3 answers Last reply
More about infocus sp61md10 power
  1. Mine is has done the same thing. I pulled out the lamp and it looked fine. I was told that the
    lamp ballast or power supply would be the next thinigs to check. Checking the lamp was the
    end of my skill level. I'd be interested in to see if someone has found the source of the problem.
    -Rob
    Thanks Tony
  3. did you ever figure out the problem?
HDTV Light Power Home Theatre
