I've recently bought a new stick of ram, particularily this one
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=140077
and in my mobo i had this one
http://www.ultraproducts.com/product_info.php?products_id=255
And I don't know if its a faulty stick of ram they sent me(the mushkin one due to it failing many windows memorytest program) or if the two are not compatable.
I've had someone say when you use your computer graphically intensly and the two ram sticks don't match you will have trouble, which is what i got and now my muskin stick of ram just totally doesn't work...and it did for the first week or two perfectly fine...so is it me mismatching my ram (and perminantly killed it)or did i just get a back stick?
thanks guys!
thanks guys!
