Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Tryin to figure out a 22-24" or so monitor to go with my build!
Forum Computer Peripherals : Flat Panels/ LCDs - Tryin to figure out a 22-24" or so monitor to go with my build!
So, I'm currently looking at this for a Gaming build...
Caedrus wrote :
Case: COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case $79.99 I want to be able to move my rig to a LAN party once in a while or something. Any good suggestions for that?
Motherboard: GIGABYTE GA-X48-DS4 LGA 775 Intel X48 ATX Intel Motherboard $224.99 (-$10 instant)
Video Card: SAPPHIRE 100243-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card $299.99
Processor: Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor $189.99
Power Supply: PC Power & Cooling S75QB 750W ATX12V / EPS12V SLI NVIDIA SLI Certified (Dual 8800 GTX and below) CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail $144.99 (-$105 instant discount, $25 mail-in rebate)
Hard Drive: Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive $84.99
Disk Drive: ASUS Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 14X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner with LightScribe $34.99 (-$5 instant)
RAM: mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory $114.99 ($20 mail-in rebate) This saves next to no money next to the 1066 version... you guys sure about this? I do notice that it has lower timings than the 1066, what's up with that?
Cooler: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler $36.99
Retention Bracket: XIGMATEK ACK-I7751 Retention Bracket $6.99
Thermal Compound: Arctic Silver 5 Thermal Compound - OEM $5.99
Operating System: Microsoft Windows Vista Ultimate SP1 64-bit English 1pk DSP OEI DVD for System Builders - OEM $174.99
This all puts the price at about $1400, Vista price included
Still missing a monitor.
And am completely stuck on a monitor. I'm really hoping to settle on what to buy within the next two days, because of the 20% discount with the promo codes that ends on the 26th.
I'm not particularly picky about size, and I would much rather have a high quality screen than a giant one.
Please help! I know next to nothing about monitors. Thanks in advance.
Message edited by Caedrus on 09-25-2008 at 03:27:01 AM
Sponsored Links
what are you using it for? If you are just gaming then a tn panel would be fine. Samsung and Lg make great monitors
Reply to chef_jd
Yes, I'm using it for gaming. Do you have any specific recommendations for an LG or Samsung monitor?
Reply to Caedrus
BenQ V2400W has been getting a lot of attention.
http://www.newegg.com/Product/Prod [...] 6824014177
Review:
http://www.trustedreviews.com/disp [...] monitor/p1
User review from Hardforum.com
http://www.hardforum.com/showthread.php?t=1315565
Order direct from BenQ (US) for $399 + free shipping until Sept 30th.
http://www.benq.us/products/LCD/?product=794
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
What about the ACER G24? and ACER G24??
Reply to viperiii
There are 1188 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
