Win & vs. modem problem
Hi y'all. I recently switched from Bell DSL internet to Teksavvy cable service. No network connection/no internet service would function on my computer. A Roger's Cable tech rep came to my apartment. His Windows XP laptop worked fine using my ethernet cable connection, which would not function on my W7 64 bit computer. The Rogers rep told me to take the one year old (3.3Ghz/ram) computer tower to where I bought it from (Canada Computers). The Canada Computers service rep hooked their DSL ethernet LAN cable to my W7 computer, and it worked fine. Back at home and using cable, the internet finally worked (after I changed my log-in user to administrator). After a few days of surfing, the network connection died again. All I get now is "Error message 651; The modem has reported an error." RCA model DCM425 is the modem. Window's "Diagnose" and "troubleshooting" functions came up with nothing. I thought it might be a virus, so I re-installed W7 a few times. Furthermore, using a different computer at a shop, I downloaded a driver for this RCA modem, but the files were not recognized by W7. I've tried doing hard resets with the RCA modem, turning it off/on, all to no avail. I even tried some advice from forum.techguy.org to command prompt "ipconfig/release" and "ipconfig/renew" in order to get the modem and computer communicating, but still no luck. I phoned Microsoft tech support, and they want $100 to "solve the problem." Teksavvy has no answers; Rogers, the same. So too for Canada Computer.
4 answers Last reply
More about modem problem
    I got a "flood" warning, thus I am splitting this post into two. Here is the other part: Windows IP Configuration
    Host Name . . . . . . . . . . . . : i-PC
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Local Area Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
    Physical Address. . . . . . . . . : 1C-6F-65-A1-0B-18
    DHCP Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    Link-local IPv6 Address . . . . . : fe80::41d3:2bee:d978:7b4%11(Preferred)
    IPv4 Address. . . . . . . . . . . : 192.168.100.10(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Lease Obtained. . . . . . . . . . : Wednesday, September 26, 2012 1:39:00 PM
    Lease Expires . . . . . . . . . . : Wednesday, September 26, 2012 1:42:26 PM
    Default Gateway . . . . . . . . . : 192.168.100.1
    DHCP Server . . . . . . . . . . . : 192.168.100.1
    DHCPv6 IAID . . . . . . . . . . . : 236744549
    DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-F3-A9-87-1C-6F-65-A1-0B-18
    DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
    fec0:0:0:ffff::2%1
    fec0:0:0:ffff::3%1
    NetBIOS over Tcpip. . . . . . . . : Enabled
  2. duplicate posts not allowed here...
  3. I did not think the 1st post went through OK. I got a ""suspected flood" warning with the 1st post, therefore I re-posted.
  4. try updating your network card drivers..driver may be damaged.
    http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
    make sure under windows network you let windows set the ip and dns servers set to auto.
    on cable modems and newer modems they look to run off one mac address. check inside the cable modem that it reading your computer mac address of your network card right. if it looks like the modem is fine try tosssing in a new network card. most time it the network card that goes bad.
Configuration Computers Cable Windows 7
