Yes No
Ads
Tom's Hardware > Forum > Computer Brands > HP > Help! why is my pc encoding so slow?
Forum Computer Brands : HP Help! why is my pc encoding so slow?
okay before i begin i should mention my specs so you can see where im coming from
hp pavilion dv4-1120us notebook
intel t5800 cpu @ 2.00ghz
4 gb ram
vista home premium 64bit
250gb hdd 5400rpm
okay so i use dvd flick alot to encode my movie files and burn them to dvd which usually takes exactly 1 hr ( all together) i takes 15 mins to burn the actual encoding of video and audio takes about 30min for a 90 min video
starting last month it has been taking me 2 hours + to complete on similar sized videos
ive done everything, mind you im no amateur with pc's. i though maybe the latest release of dvd flick was making me so slow so i searched the far corners of the web for an earlier release and it cut the time by 10 minutes maybe at most. i used cc cleaner and defragged my hdd. i even installed windows xp and still no luck.
i unistalled all crapware mostly with pc decrapifier. after that didnt work i used restore disks to restore back to original state with vista, ran pc decrapifier, defragged and cc cleaned. nope still 2 hrs. i reseated ram and dusted cpu fans.
fyi this computer is a little over a year old, and for a good year it has been encoding alot and still kept up untill last month
my only thought now would be maybe its a heat issue since the fans are pretty loud now. i might reapply thermal paste with some artic silver 5. and i had already planned on upgrading my processor to a intel t9600 or t9900, i'll get of ebay. i know it will work because hp originally offered those processors with my notebook
any help is greatly appreciated!
Reply to cowtipper666
There are 1974 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
