Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Dell > Altec lansing ADA995 subwoofer
Forum Computer Brands : Dell Altec lansing ADA995 subwoofer
Altec Lansing ADA995 subwoofer System Defective . Only the Front Speakers work. Anyone have technical info including Schematic diagram that would aid me in repair??
Reply to Tinwillie4128
I have the system, missing the front left speaker. Are you interested in selling?
Reply to hakstar
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a b*tch. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
Reply to alanp
There are 1948 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
