Archived from groups: microsoft.public.windowsxp.general (More info?)
I just did a fresh load of XP Pro but have a few minor but very annoying
problems.
1. In a folder window (ie My Computer or Explorer) the title bar only shows
the first letter of the path. If the path is C:\temp the "C" is displayed if
D:\archive then "D" is displayed. I have tried going to "Tools--->folder
option ---->view and select "show full path in title bar" and checking and
unchecking. I have tried different fonts and different size fonts.But still
the title bar is unchanged.
2. If I set up a shortcut key in a short cut, most will not launch but a
couple will.
Do you have the Address bar showing also?
Right click Toolbar | Select Address bar
Open Folder Options...
Start | Run | Type: control folders | Click OK |
View tab | Select: Display the full path in the address bar |
Click Apply | Click OK
[[Specifies that the complete path of the open file or folder is displayed
in the address bar of the window.]]
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:Ea2dnT6zK4w3MXzfRVn-tw@taconic.net,
JG <JG@JG.com> hunted and pecked:
> problems.
> shows the first letter of the path. If the path is C:\temp the "C" is
> displayed if D:\archive then "D" is displayed. I have tried going to
> "Tools--->folder option ---->view and select "show full path in title
> bar" and checking and unchecking. I have tried different fonts and
> different size fonts.But still the title bar is unchanged.
> couple will.
Hello
Hope I ddn't miss read your reply but I'm not having any trouble with my
address bar it is the "Title Bar" that isn't showing any file path , just
the first initial of the path.
"Wesley Vogel" <123WVogel955@comcast.net> wrote in message
newsqFMzGzjFHA.3960@TK2MSFTNGP12.phx.gbl...
> Wes
>> problems.
>> couple will.
