Cable/satelite remote
How can I program my direct TV remote to work with my scientific Atlanta cable box as well. I have both cable and satelite boxes hooked up to one TV and want to use the direct tv satelite remote
1 answer Last reply
More about cable satelite remote
  1. The DirectTV remote is fully programmable and already has the most common manufacturer codes....you just have to go into the menu, select "program remote" and follow the steps.
    This DirectTV page might help you with the process..
    http://support.directv.com/app/answers/detail/a_id/1343/kw/program%20remote/r_id/104513
Satellite TV TV Cable Home Theatre
