Hi Speed USB2
Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
Hi
I have USB2 on my PC, on my Asus P5GDC MoBo with P4 3.2ghz/1.5gb ddr RAM, Xp
SP2 etc etc.
When I plug my iPod into it it states it will run at a reduced speed because
I don't have the latest controllers for my USB.
Microsoft Knowledge base tells me to update to latest Service pack, which I
already have (not separate install, it was a fresh XP SP2 install).
Any ideas how to activate the USB2 capabilities on this?
Many Thanks.
Nik.
8 answers Last reply
More about speed usb2
  1. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    According to Asus's product specifications, that Motherboard
    has up to 8 USB ports and all are 2.0 compliant. Aside from a
    Service Pack you might need the Intel Chipset Driver package.
    This installs system/core component drivers. Also, BIOS will
    have configuration options for USB. You should probably go
    through the setup and ensure that USB is configured for High
    Speed (USB2.0) operation.
    The latest version is 7.2.1.1003, that you can get from the Intel
    Downloads page:
    http://downloadfinder.intel.com/scripts-df-external/Filter_Results.aspx?strOSs=44&strTypes=DRV,ARC&ProductID=816&OSFullName=Windows*%20XP%20Professional
    "Nik" <nik.walmsleySPAMKILL@btinternet.com> wrote in message
    news:dbt713$p11$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com...
    > Hi
    > Xp
    > SP2 etc etc.
    > because
    > I
    > Many Thanks.
    > Nik.
  2. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    Thanks for such a great (and quick) reply!
    Nik.
    "R. McCarty" <PcEngWork-NoSpam_@mindspring.com> wrote in message
    news:O1eoWW3jFHA.3144@TK2MSFTNGP12.phx.gbl...
    > Downloads page:
    >> Hi
    >> Xp
    >> SP2 etc etc.
    >> because
    >> I
    >> Many Thanks.
    >> Nik.
  3. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    The problem I have is that I don't understand why SiSandra reports that the
    speed is "FULL"? :-
    SiSoftware Sandra
    General Information
    Controller : Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
    Root Hub
    Compound Device : No
    Hub Is Bus Powered : No
    Power Switching : None
    Over-current Protection : Individual
    Number of Ports : 2
    Root Hub: USB Port 1
    Status : No Device Connected
    Root Hub: USB Port 2
    Status : Device Connected
    Device Connected to Port : USB Mass Storage Device
    OEM Device Name : Apple Computer, Inc. ??? (1205)
    Device Version : 0.01
    Device ID : VEN_05AC, DEV_1205, PRT_00
    USB Version : 2.00
    Speed : Full (12Mbps)
    Configuration Settings : 1
    Open Pipes : 2
    Transfer Type : Bulk
    Data Packet Size : 64 byte(s)
    The device is connected to the front ports on my PC, and I'm wondering if it
    needs to be a direct connection (I.e. it sees the front ports as a hub?)
    could this be the problem?
    Thanks again.
    Nik.
    > Downloads page:
    >> Hi
    >> Xp
    >> SP2 etc etc.
    >> because
    >> I
    >> Many Thanks.
    >> Nik.
  4. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    Full is the nomenclature for the original USB 1.0 standard.
    High Speed is the description for USB 2.0. I can't speak to the
    Intel 915 based chipset. On my 865 chipset the BIOS setup will
    allow you to configure USB for either operating mode. In effect
    you can turn off USB2.0 and force USB1 level performance.
    As far as Device Manager is concerned, you'll have a number
    of Host controllers that serve a Root Hub that provides the USB
    slots or channels. From your Sandra data it appears that the
    Controllers are set to Full Speed operation. I would still check
    BIOS and confirm the settings for USB.
    news:dbt937$p5r$1@nwrdmz02.dmz.ncs.ea.ibs-infra.bt.com...
    > the speed is "FULL"? :-
    > SiSoftware Sandra
    > General Information
    > Root Hub
    > Number of Ports : 2
    > USB Version : 2.00
    > Open Pipes : 2
    > it needs to be a direct connection (I.e. it sees the front ports as a
    > hub?) could this be the problem?
    > Thanks again.
    > Nik.
    >> Downloads page:
    >>> Hi
    >>> RAM, Xp
    >>> SP2 etc etc.
    >>> because
    >>> which I
    >>> Many Thanks.
    >>> Nik.
  5. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    Cool, will do. Thanks again for the advice.
    Nik.
    news:%238XR0n3jFHA.3012@TK2MSFTNGP12.phx.gbl...
    >> SiSoftware Sandra
    >> General Information
    >> Root Hub
    >> Number of Ports : 2
    >> USB Version : 2.00
    >> Open Pipes : 2
    >> Thanks again.
    >> Nik.
    >>> Downloads page:
    >>>> Hi
    >>>> RAM, Xp
    >>>> SP2 etc etc.
    >>>> because
    >>>> which I
    >>>> Many Thanks.
    >>>> Nik.
  6. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    I had this problem recently with my ASUS P533-VM board. Actually, the
    problem may have been there for years since we did not use the USB ports for
    anything until now. This is what I found out. Others have had similar
    problem with ASUS and some other brand also and in the case of ASUS the
    solution is to increase or decrease the BIOS setting for the power supplied
    to the USB. Setting it too high (there are four settings on my ASUS - Low,
    Normal, High and Very High, actually the wording may be different, I just do
    not remember at the moment). Setting this to too high makes the USB port
    turn on and off every few seconds. Too low and only USB 1 available.
    Regardless on the setting that makes it work, it does not work too well and
    I gave up on it after while. Since the warning comes on every time you plug
    in a USB 2 device in one of the ports, there is a setting in the driver to
    turn off this warning.
    Pavel
    > Hi
    > Xp
    > SP2 etc etc.
    > because
    > I
    > Many Thanks.
    > Nik.
  7. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    http://www.u3.com/
    interesting facts.
    regards,
    ssg MS-MVP
    > Nik.
    >>>SiSoftware Sandra
    >>>General Information
    >>>Root Hub
    >>>Number of Ports : 2
    >>>USB Version : 2.00
    >>>Open Pipes : 2
    >>>Thanks again.
    >>>Nik.
    >>>>Downloads page:
    >>>>>Hi
    >>>>>RAM, Xp
    >>>>>SP2 etc etc.
    >>>>>because
    >>>>>which I
    >>>>>Many Thanks.
    >>>>>Nik.
  8. Archived from groups: alt.comp.hardware,microsoft.public.windowsxp.general (More info?)
    On Sat, 23 Jul 2005 17:50:21 -0700, "Pavel" <Atin90@hotmail.com>
    >> Hi
    >> Xp
    >> SP2 etc etc.
    >> because
    >> I
    >> Many Thanks.
    >> Nik.
    Nik
    I had the same problem with a Asus MB A7V333 it wouldn't let my ipod
    use USB2, I went to the Via website and downloaded the USB2 driver and
    installed and now no probs with ipod. I don't know if your MB uses the
    via chipset for usb.
    James
    Take the FUN out of my email address to reply.
    They think it's all over... it is now.
Microsoft Windows XP
