Cybershot dsc-w320 problems
Hello,
hi all I have purchased this camera and am unsure if its faulty or if its just me?the zoom isnt very close,and when i aim at something it takes ages to take a pic and usually missed object then,and if i aim straight sometimes it doesnt take pic of the object in front,takes pic of whatever is in left hand corner,any help and advice would be gratefull,as tryin to use it lots at the mo,thanks,Kath,
1 answer Last reply
More about cybershot w320 problems
  1. Just in case you aren't using it correctly, have a look at the literature which came with the camera and go through the basics of taking a shot. Find the option to reset the camera to its default settings.
    You'll probably find a fuller manual on the CD which came with the camera or on the maker's website, if any part of the procedure is not clear.
Cameras Zoom
