new monitor problem
Forum Computer Peripherals : Flat Panels/ LCDs - new monitor problem
I just switched out from a bulky big monitor to a flat screen one and I'm seeing wavy lines all the time on this new flat monitor, its hard to explain..but its there, starting to make me dizzy. Any one know whats up? Thanks a lot.
Sponsored Links
What model specifically?
Any more details?
It's difficult to help at all with that little information.
Message edited by cjl on 11-21-2008 at 08:13:00 AM
Reply to cjl
- 0 +
Ah, right, sorry, its a gateway 700g flatscreeen monitor.
Reply to turret
- 0 +
Hmm...
I can't seem to find much detail on that monitor - it seems to be an older model. Does it have multiple inputs (DVI/VGA), and if so, did you try using a different input?
Reply to cjl
- 0 +
Yes, but the cord I have only fits in the analog vga spot, I can't find any spares around here that'll fit the second plugin.
Reply to turret
- 0 +
well my monitor is doing the exact same thing. but that is a 2,5 years old mirai. if you have this problem on a new one, you should make an RMA.
also, i can barely spot the waves when i turn the brightness up. try that.
Reply to koogco
I would try to borrow a VGA cable.
I had an issue sometime ago with one of my LCD monitors. The distortion was taken care of by replacing the VGA cable.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > new monitor problem
There are 1112 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
