Archived from groups: microsoft.public.windowsxp.general (
More info?)
22 should be OK, as your Motherboard has an APIC which extends
normal IRQ mapping from 15 up to 23. However, IRQs have priority
and placing a Sound Card that high in the signaling tree may not be an
optimal setting. I would probably move the Sound card to Slot #2 or
Slot #5 which should give it an independent IRQ with a higher priority
such as 5 or 10.
"abad0412" <abad0412@discussions.microsoft.com> wrote in message
news:628B7125-8388-4A64-B6AC-B48520EBA5C8@microsoft.com...
>I ran MSInfo32.exe. My Turtle Beach sound card is assigned to IRQ 22, but
> Microsoft ACPI-Compliant System and NEC PCI to USB Open Host Controller
> are
> also assigned to IRQ 22.
> I've updated all my software and drivers. Thanks.
> "R. McCarty" wrote:
>> The reason I asked that question is that most motherboards only
>> provide 2 independent IRQ slots in them. Most recent PCI cards
>> can handle IRQ Sharing without any issues. You may be right if
>> this is a recent occurrence that didn't involve any hardware changes.
>> Anyway, I would run MSInfo32.Exe, Expand Hardware Res. &
>> then click into the IRQ mapping and see where your Turtle Beach
>> is assigned. If it isn't sharing an IRQ then that isn't likely your
>> cause.
>> Have you checked for a MusicMatch update lately ? -or updated
>> any other multimedia type app that might have replaced or updated
>> any Codecs.
>> news
F1F1F15-4A29-4036-AB16-12C0DE8A1407@microsoft.com...
>> >I don't think this is a PCI Slot issue since I did not have this problem
>> > until recently but the card is in slot 1. Thank you.
>> > "R. McCarty" wrote:
>> >> Which PCI Slot is the card installed into ? Numbering schemes
>> >> vary, but Slot #1 is generally considered to be adjacent to the
>> >> AGP slot (Light Brown in color, shorter than White PCI connectors).
>> >> news:9DB32218-F476-49B8-A85E-39046AFF0541@microsoft.com...
>> >> > I'm having problems with my audio. When I am playing music and
>> >> > using
>> >> > the
>> >> > PC
>> >> > at the same time, the audio output distorts and breaks up. I have
>> >> > Windows
>> >> > XP
>> >> > Home Edition and use Musicmatch for my mp3 files. My soundcard is
>> >> > Turtlebeach Santa Cruz. My PC is a Sony PCV-RX560 with 512mb of
>> >> > RAM.
>> >> > Can
>> >> > anyone suggest a fix/solution? Thank you.
