Closed
Help me please on this c++ problem
Last response: in Work & Education
Some numbers like 153, 370, 371, 407, … have the property that the number equals the cube sum of its digits. For example:
153: 13 + 53 + 33 = 1 + 125 + 27 = 153
(the left side of the equation is confusing. He means "1cubed+5cubed+3cubed" but that's not possible to write here correctly)
370: 33 + 73 + 03 = 27 + 343 + 0 = 370
371: 33 + 73 + 13 = 27 + 343 + 1 = 371
407: 43 + 03 + 73 = 64 + 0 + 343 = 407
Write a program that prompts the user to enter two positive integers lower and upper, then finds and prints all numbers in the interval [lower, upper] that have the property that the cube sum of the digits equals the number itself. The program also prints the how many numbers have the cube sum property.
More about : problem
Best solution
solution:
#include<iostream>
#include<string>
using namespace std;
int getLastDigit(int & num)
int r=num%10;
num=num/10;
return r;
bool IsCube(int A[], int num,int count )
int sum=0;
while(count>=0)
sum=(A[count]*A[count]*A[count])+sum;
count--;
if(num==sum)
return true;
return false;
void main()
int A[100]={0};
int start=0;
int end=0;
int temp=0;
int i=0;
cout<<"first number:";cin>>start;
cout<<"second number:";cin>>end;
if(start>end)
cout<<"\nInvalid Interval\n";
exit(0);
for(int num=start; num<=end; num++)
i=0;
temp=num;
while(1)
A=getLastDigit(temp);
if(temp==0)
break;
i++;
if(IsCube(A,num,i))
cout<<num<<" is a cubic sum\n";
Ask the community
