Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > XP doesn't work after system reset
Forum Windows XP : Windows XP General Discussion - XP doesn't work after system reset
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have developed a very strange problem on my PC, everytime I have to press
the reset button on my case, or there's a power cut when Windows reboots, it
will boot to the desktop fine and I can move my mouse but no windows, no
programs or anything will open.
This problem is driving me insanse, the only way I can get windows working
again is to do a system restore to the a point before I pressed the reset
button.
I recently reformatted my drive and re-installed to overcome this problem
but it hasn't. It was the same with SP1 and SP2, I've had this machine(a64
3000+, 1gb RAMM) for well over a year and this problem only developed in the
last couple months.
Can anyone please help? I can't believe a reformat didn't fix the problem,
although I did choose the quick format option and when I installed a program
I had on before hand, it said was 'trial was up' which makes me think I
didn't fully erase all of the old files. Although everything seems brand
new, I had to re-activate too.
Sponsored Links
On rare occasion I have seen this when the power supply is acting flakey or
just about to fail. Try a different power supply, maybe one with more watts
IE 450, etc.
If that didn't help or resolve the situation, then it is process of
elimination. It could be memory as well. I had a situation where memory
failures ere causing all kinds of weird problems. Also, graphics drivers,
make sure you have the latest.
The problem is that we all don't have all these parts lying around to test
with.
Hope this helps.
"mark" <mark@localhost.net> wrote in message
news:42e2a9de$0$24471$ed2619ec@ptn-nntp-reader03.plus.net...
>it will boot to the desktop fine and I can move my mouse but no windows, no
> button.
> the last couple months.
> program I had on before hand, it said was 'trial was up' which makes me
> think I didn't fully erase all of the old files. Although everything seems
> brand new, I had to re-activate too.
Reply to Anonymous
>button.
>last couple months.
When that happens try totally powering off the machine by unplugging
the power cable. That should reset the BIOS to a totally "cold"
state and allow it to start up.
If doing that does resolve the problem then you have a problem with
either the BIOS configuration (check the Power Management settings,
try restoring them to factory defaults) or with the computer hardware
itself (motherboard or power supply)
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Reply to Anonymous
There are 1225 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
