what is the possible solution of dell laptop when it has power problem? and could be the component bad and solution.
Sponsored Links
It could be dozens of things. Please provide more details on your situation.
Reply to frozenlead
when plugged on light doesn't show on the laptop it self
Reply to Anonymous
it's not turning on
Reply to Anonymous
Did you just get to it today and it didn't boot? Did it shut off randomly? Does the LED on the power supply light up? Will the notebook boot on battery power?
Reply to frozenlead
- 0 +
I saw your reply to this issue. Mine is similar.
My Inspiron 1721 shut down and will not turn back on. Absolutely no lights or noises when the power button is depressed. All five LED's on the battery are lit constantly. When I push the battery check button three of the five (every other one) flash several times, then the lights go out and then a couple of seconds later all LED's relight. The power supply works fine (tested on another Dell), but when I plug it in (with or without the battery installed) the light on the AC Adaptor goes out. It will reset once I pull the plug and then plug it back into the wall. Any ideas on what the problem may be?
Reply to paul s
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Power problem
There are 545 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
