well its been about a week that i bought if of newegg.com for the first day it worked good. then i started to play bioshock and world of warcraft the screen would turn off randomly. then i downloaded the drivers to see if that was the problem and it did fix it for a while then when i would be playing the monitor would flicker. i put it on dvi and then switched to vga and it seemed to be the same problem. so how can i fix it. and thanks i have a 7900 gtx and the driver is updated.
