Archived from groups: microsoft.public.windowsxp.general (More info?)
I just bought an external USB drive to back up my system. During the
installation process it said that there were no High Speed Ports on my
system. It said I can still use the drive, but the back up process would be
slower. It is VERY slow.
Two questions:
Is it possible to easily install a new USB port or replace the one there
already?
My knowledge is limited, but can the one I have be upgraded with a new
driver?
Ok. It's not going to be upgradeable very easy. You chould get a PCI card
that has a few ports. If you got a laptop, you'll be able to get like 2/4
Desktop pci cards'll get up to 6/8
> Two questions:
> already?
> driver?
> Thanks, Gene
You cannot upgrade existing USB 1.1 ports since they are likely connected to
the Motherboard. What you can do is buy a USB 2.0 PCI (Peripheral Component
Interconnect) cars which can be installed in any open PCI slot in your PC.
They come with from 2-5 slots and can be purchased at Best Buy, Circuit
City, Staples, Office Max, Office Depot, Wal-Mart, Radio Shack, plus anybody
else that sells computer parts at retail. About $30-$40 most places. Easily
installed.
Gene K
"Aloha" <bigislandhilo@hotmail.com> wrote in message
news:Q%DEe.4522$6M3.2491@trnddc03...
>be slower. It is VERY slow.
> Two questions:
> already?
> driver?
> Thanks, Gene
USB 1.1 ports are controled by a chip. You can not upgrade this chip to USB
2.0.
However, check you motherboard manual so as to make sure that these USB 1.1
ports are truely USB 1.1 ports. You need SP1 (or SP2) in order to activate
USB 2.0 drivers correctly.
"Gene" <nobody@nowhere.net> wrote in message
news:ea1729LkFHA.3288@TK2MSFTNGP09.phx.gbl...
> to the Motherboard. What you can do is buy a USB 2.0 PCI (Peripheral
> Component Interconnect) cars which can be installed in any open PCI slot
> in your PC. They come with from 2-5 slots and can be purchased at Best
> Buy, Circuit City, Staples, Office Max, Office Depot, Wal-Mart, Radio
> Shack, plus anybody else that sells computer parts at retail. About
> $30-$40 most places. Easily installed.
> Gene K
>> Two questions:
>> already?
>> driver?
>> Thanks, Gene
Hey i did the same thing and got the same results. Are there any adapters out
there
(PCIx to USB 2.0) that can be used in order to speed up the process at all.
I have a Dell PowerEdge 2650 and USB is only version 1.0. Researched like
crazy on Google to try and find PCIx to USB 2.0 adapter and came up empty.
kevc
GCStech
> Two questions:
> already?
> driver?
> Thanks, Gene
I have a 5 port PCI USB 2.0 adapter from Belkin...available even at
WalMart...
A Professional Amatuer...If anyone knew it all, none of would be here!
"kevc" <kevc@discussions.microsoft.com> wrote in message
news:4641C329-D4A5-49EE-8C8C-831496566B71@microsoft.com...
> out
> there
> all.
> kevc
> GCStech
>> be
>> Two questions:
>> already?
>> driver?
>> Thanks, Gene
