I just bought myself a new Western Digital SE Caviar 200GB SATA harddrive (WDC WD2000JD-00HBB0). I went to a computer store to set it up because I never set up a SATA drive before, come back home, boot up the pc, everything runs fine except when I run Everest Home Edition it tells me my drive is IDE???
It gives me the correct model number and on Western's site it says it's a SATA drive but still.. what could possibly make it an IDE???
CPU Type Intel Pentium 4 530, 3000 MHz (15 x 200)
Motherboard Name MSI 865PE Neo2-PS (MS-6728 v2.0) (5 PCI, 1 AGP, 4 DDR DIMM, Audio)
Motherboard Chipset Intel Springdale i865PE
System Memory 512 MB (PC3200 DDR SDRAM)
BIOS Type AMI (09/29/04)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM3)
Communication Port ECP Printer Port (LPT1)
Storage:
IDE Controller Intel(R) 82801EB Ultra ATA Storage Controllers
Disk Drive WDC WD2000JD-00HBB0 (186 GB, IDE)
Optical Drive HL-DT-ST DVD-ROM GDR8160B (16x/48x DVD-ROM)
Optical Drive LITE-ON LTR-40125S (40x/12x/48x CD-RW)
SMART Hard Disks Status OK
[ WDC WD2000JD-00HBB0 (WD-WMAL81523218) ]
ATA Device Properties:
Model ID WDC WD2000JD-00HBB0
Serial Number WD-WMAL81523218
Revision 08.02D08
Parameters 387621 cylinders, 16 heads, 63 sectors per track, 600 bytes per sector
LBA Sectors 390721968
Buffer 8 MB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 74
Max. PIO Transfer Mode PIO 4
Max. UDMA Transfer Mode UDMA 6 (ATA-133)
Active UDMA Transfer Mode UDMA 6 (ATA-133)
Unformatted Capacity 223573 MB
Storage:
Revision 08.02D08
Multiple Sectors 16
ECC Bytes 74
