Tom's Hardware > Forum > CPU & Components > Sound Cards > NEED SOUND CARD DRIVER!!!!
Forum CPU & Components : Sound Cards - NEED SOUND CARD DRIVER!!!!
I have just installed a fresh copy of Windows HOME with service pack 2 on a HP pavilion 752n and it does not have sound. I need a sound driver and hp website doesn't have it. I contacted them and they couldn't help me. I need one that is compatible with my pavilion 752n and I have searched but no luck. I don't have the recovery cds. Anyone have advice?
Sponsored Links
You may find what you need <A HREF="http://www.driverguide.com" target="_new"> here </A> you have to register at DriverGuide to use the site and its free.
Finding either the name of the soundcard or the name of the onboard sound chipset on the M/B will greatly help, theres probably 20 or so pages of drivers at the site so you'll have to do some looking, but start your search spelling out Hewlett Packard not HP, and it will take you to all the available HP drivers, Good Luck!
<A HREF="http://forums.btvillarin.com/index.php?act=ST&f=41&t=2541&st=0#entry20385" target="_new">System Specs</A>
Reply to 4ryan6
If you have the manual it might tell you the motherboards model, and then you can search in the mobo manufacturer's website for the driver.
Nothing is as easy as it looks
Reply to dunklegend
It is likely to be one of the following manufacturers:
SoundMax
Realtek
C-Media
If its a separate soundcard then its bound to be a Creative Audigy 2 since those are the only separate soundcards which HP use in their PCs.
Surely HP should provide the neccesary drivers in the form of a recovery CD, check your packaging or otherwise call HP! www.driverguide.come is a good place for drivers
Username: Driver
Password: All
PC Spec: AMD Athlon XP 2000+, ECS K7S5A Motherboard, 768MB SDRAM PC133, Sparkle nVidia Riva TNT2 M64 32MB AGP Graphics Card, Creative Sound Blaster Audigy 2 6.1, Windows XP
Reply to marshahu
There are 495 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
