Enter for a chance to win a Ballistic Gaming Computer.
my monitor, has a weak spring, when I open it the screen will not stay at position. I have to prop it up.
The easiest thing to do is to try to tighten up the screws which holds your screen. If that won't help, you'll have to get a new hinges to replace your old ones (try eBay).
