Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > General Discussion > Serious lag, can't figure out why...
Forum Laptops & Notebooks : General Discussion Serious lag, can't figure out why...
Okay, so... It started a few days ago that my computer began lagging something fierce. I've run anti-viruses, malware removal, even wiped everything out, deleted partitions, and reinstalled Windows XP... Twice. I have no idea what could be causing the lag. It lags when I type, open programs, try to come out of screen saver, pretty much everything. Here's all the spec stuff I saw in the "read before posting" thread... Any help would be appreciated.
Dell Vostro 1000
AMD Turion 64X2 Mobile
2gig ram
Reply to grimorian
Could be heat, or a bad had disk. I'd check both of those possibilities out.
Reply to frozenlead
How would I check a bad hard disk?
Reply to grimorian
I found www.hdsentinel.com a while back and have been extremly happy with it for checking state of Harddisks.
Reply to delamere
I wouldn't use a web site to check your hard disk. It's just a bad idea.
If you don't have one already, the hard disk utilities on the Ultimate Boot CD are invaluable (not to mention everything else on the disk). I would use those. The IBM/Hitachi utility is my favorite.
Reply to frozenlead
- 0 +
This is all good stuff - but there's a solid chance you don't have the correct chipset drivers.
A common problem with running x64 architecture.
Could also be video drivers.
Did you install win xp 64-bit edition?
With a computer of that speed, you may want to consider installing the new windows 7 x64 (download from technet.com).
It is always a good idea to address software issues before you start diagnosing the hardware. Simply because it is easier and sometimes more likely.
How old is the machine?
------------------------------ Check out an awesome PvP MMO: http://bit.ly/dexUl1
or
My girlfriend's Etsy: http://snappdragyn.com
Reply to ampedal
It is a few years old, and it worked fine until a week ago, when it started lagging. I thought maybe a virus or malware, but every scan with multiple software's yielded nothing. It's something that happened out of nowhere, I didn't install or change anything before it started happening.
Not sure if it's the 32 or 64 XP, it's whatever came with the machine
PS: it took me like 10 minutes to type this reply out... LoL.
Reply to grimorian
Is there any process using a significant amount of memory or processor time?
Reply to frozenlead
- 0 +
Typically hardware problems crash your machine, or don't let you start up in the first place. Which is why I'm leaning towards it being a software issue.
Have you tried contacting dell?
How about downloading all the correct drivers for this model? You can find the driver download center on dell's site - somewhere near the support section...
or
Reply to ampedal
Downloaded all drivers, no change. System Idle Process is in the 90's, so there's nothing really being processed. It just lags. I am at a total loss as to what it could be.
Reply to grimorian
Does it still act slow in Safe Mode?
Reply to frozenlead
No, it does not lag in safe mode. But, now it's doing it sporadically. It's good for a few seconds and then laggy the next.
Reply to grimorian
Well, it's most definitely a software issue. You can start disabling things you don't need in msconfig and see if a change occurs.
Reply to frozenlead
- 0 +
head over to technet.com (owned by Microsoft)
download windows 7 for free, install it, report back.
this should fix 98% of your software issues.
after the 90-day trial expires: if you're a student you can get win 7 pro for $30 - best Microsoft deal I've seen in a while. If not, at least you'll know that your problem can be fixed by an upgrade.
or
Reply to ampedal
- 0 +
just a slow hard disk, put new hard disk drive.
------------------------------ http://www.youtube.com/reply4reply
Reply to pcfixed
Windows 7 free trial has ended... And why would a slow hard disk cause typing lag as well as the other lag all of a sudden?
Reply to grimorian
- 0 +
...it wouldn't because it's clearly a software issue
or
Reply to ampedal
Well getting back to software issues, what is essential for me to keep running in msconfig? And just to note, there is nothing but Windows XP Professional on my computer. I deleted everything and reformatted the HDD twice in hopes it would stop the lag and it obviously hasn't.
Reply to grimorian
That's strange. If you've reformatted, that definitely points to a hardware issue.
Does your HDD activity light pop on when it lags?
Reply to frozenlead
- 0 +
1. Run memtest86
2. Technet.com - download the Windows 7 RTM 90-day trial.
This will clear up 90% of issues.
The hardware stuff is all good - but it easiest to address software issues first. As a general rule.
or
Reply to ampedal
- 0 +
and just saw your post about windows 7 trial being over - don't know where you read that.
you can get it here:
http://technet.microsoft.com/en-us [...] ID=wtcfeed
select your chipset at the bottom of the page - and you're on your way!
or
Reply to ampedal
I tried that site, but I get to the please wait your downloading is coming page and it quickly goes to the windows 7 site and never starts downloading anything.
Reply to grimorian
- 0 +
you need a windows live account
or
Reply to ampedal
- 0 +
I don't know what to tell you...it's very hard to diagnose these kind of problems - but you really have to be proactive about it if you want to fix anything.
If you're not a computer enthusiast - this probably isn't the place for you. We're not here to fix your computer, it's more of a place to learn.
If you want someone to fix your computer, considering purchasing extended warranties or visiting the local computer repair shop.
Sorry I couldn't be more help to you...
or
Reply to ampedal
I'm not asking anyone to fix my computer. The tone of your reply makes it seem like you've given me all this valuable information that I've done nothing with, when in actuality, all you've given me is "It's either a hardware or software issue."
No really?
Also, downloading is not rocket science, if I say I can't get the trial to download, than I can't get it to download. I even made a new account and it wont work. My conclusion that the trial might have ended came from the sentence posted on the page before the download is supposed to start, which said "The 90-day Trial is offered for a limited time and in limited quantity. The download will be available through March 31, 2010, while supplies last."
So, to start over, the only "software" on this computer is Windows XP. So if it's a hardware issue, I just need to know what could be messing it up that would cause lag but not any system start up errors and what not. And if it's software, all that's on here is Windows, and it's the windows that came with the machine.
Message edited by grimorian on 10-26-2009 at 05:18:34 PM
Reply to grimorian
You said you reinstalled Windows, correct? Did you install drivers and such after that, and it started lagging, or did it start lagging on the first bootup of the fresh install?
Have you tried popping in a Linux live CD? If it lags with that it's definitely a hardware issue.
Reply to frozenlead
I actually didn't think to try doing anything after the fresh install before I loaded up the drivers. I could give that a try I guess. As for the Linux, no I haven't tried it, not too familiar with Linux, but I can probably give that a try.
Reply to grimorian
- 0 +
I wasn't trying to flame you -
it seems like you wanted me to do more work than you were willing to invest...
as for me telling you it's either a hardware or software issue - I don't see where I ever said that.
did you run memtest? did you google windows 7 90-day trial? did you put any effort into trying to install a different o/s?
"No, it does not lag in safe mode." - grimorian
that points a really big arrow that it's a software issue...
or
Reply to ampedal
Ok, I finally got a copy of Windows 7 trial, and so far, the lag is gone.
Reply to grimorian
- 0 +
good stuff I'm glad to hear it!
I just figured out the "window compare" feature - very very cool.
or
Reply to ampedal
There are 1460 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cant log into windows 7
By anort3, 2 days ago:
Sorry, we can't help you get around a password as we have no way of knowing if you are...
Best offers
Top experts
