Tom's Hardware > Forum > General Networking > Network General Discussions > need help with ADSL connection
Forum General Networking : Network General Discussions - need help with ADSL connection
Dear Friends,
I'm having some problems with the ADSL I have just installed.
Although the max bandwidth is 256kbps, I am only getting 40 to 50 kbps.
This problem happens only with my computer. I installed the ADSL modem in my brother's computer and it worked with the max bandwidth.
The strange thing is that in both computers the connection was made with the same adsl modem, same ethernet PCI card and same phone line. So why it is not working properly in my computer ?
My set is a AMD k2-300, mobo epox ep-58MVP3c-m, 256 MB RAM.
My brother's is Pentium III 800, asus mobo and 64 MB RAM.
Is there any reason for the problem ?
Thanks,
Yan
Sponsored Links
I'd be reasonably willing to say that your slow PC is the problem. Faster PC will cure it.
<i>It's always the one thing you never suspected.</i>
Reply to jlanka
My slow PC can make things work slower but I guess it has nothing to do with the bandwidth.
It makes no sense.
This ADSL connection should work even with a Pentium 133.
Reply to yangrossman
How are you measuring your bandwidth?
Reply to jlanka
With a software called bandwidth meter and with online speed tests.
See, I'm no expert (maybe one will crop up) but I'm under the impression that your PC is an integral part of those tests. Unless they're simply pinging it, then it makes no sense.
Good luck.
Reply to jlanka
Sounds to me like you need to tweak your MTU's and Rwin ( maximum transmission units and receive window) I strongly recommend you go to www.dslreports.com. download Dr.TCP, run the tweak test on the "Tools" page, run Drtcp and set the recommended numbers from the tweak test into the mtu and rwin windows, reboot and run tweak test again followed by a speed test. You will need to know if you have a PPPoE or other type connection . The forum boards there are excellent also for advice much like the boards here at Tom's
Lagger
<b><font color=blue>I'm a NASTY Intel\AMD\Nvidia\ATI user and I'm just gonna TAKE that d@mn cookie</b> </font color=blue>
Reply to lagger
There are 1195 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
