Help with my N2750w Viewsonic
Last response: in Other Consumer Electronics
Check the connection to the computer, swapping the cable if you can and trying the monitor with another computer.
The symptoms suggest faulty connection to the monitor or faulty video card in the computer.
Thanks for the advise, cables and connections are good - however I use the Viewsonic N2750w as a television and not a computer monitor. Any other ideas - anyone?
Thx,
Mike
Ask the community
