Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Help: Go with a 26" monitor now, or wait for 3D monitors later
Forum Computer Peripherals : Flat Panels/ LCDs - Help: Go with a 26" monitor now, or wait for 3D monitors later
I'm deciding on whether to get the Samsung T260HD or wait for a 26"+ equivalent 3D monitor.
I don't mind spending around $500 but not more than $600.
I need a lot of connectivity, for various consoles, and of course my PC.
I like the T260HD but I'm not in any rush to get a monitor right now if waiting for a 3D monitor at that size and a decent price isn't a pipe dream. Plus, I have no idea how well the 3D systems actually work since I've never used one.
Anybody have any advice on what I should do?
Sponsored Links
3D monitors are a pipe dream. If it's actually perfected, do you actually think it will cost no more than $600?
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
Sorry I was talking about 120HZ monitors for use with things like
this: http://www.nvidia.com/object/GeFor [...] _Main.html
Reply to w3wizard
I would wait for a review first. Sounds great on paper (like anything can), but you wanna find out if that think can give people headaches and if it actually works for all games (if any).
Reply to jaguarskx
I went and got the T260HD, now I'm going to (most likely) return it.
The color quality is worse than my existing Gateway monitor. Add to it that the total backlight life is 20,000 hrs with 90% certainty, and that it's under spec and I'm not happy.
I guess I'll try to fix the color through Nvidia's CP but I can't yet find a good mix that will get me anywhere near the quality on my Gateway. All the colors are just... dull.
Reply to w3wizard
- 0 +
Nvidia has a 22" bundled with the glasses for $598.00
Reply to akandy
There are 1272 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 EChiasson won the Freshman badge
  • 01:00 Foxer57 won the Uniformed badge
  • 01:00 gregmo won the Freshman badge
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
