Tom's Hardware > Forum > Audio > Audio Technology > Help for Audigy SE
Help for Audigy SE
Forum Audio : Audio Technology - Help for Audigy SE
Hi, I recently purchased the Audigy SE soundcard. The installation went smoothly, and the auto-update function installed the latest drivers. So far, so good. But when i run the Diagnostics tool, here's what I got:
Creative Diagnostics Test Log
Detected device:
SB Audigy
Tested device:SB Audigy
09/05/2009 08:47:48PM Drivers Tests Pass
09/05/2009 08:47:52PM Windows Multimedia Tests Pass
09/05/2009 08:47:53PM DirectSound Tests Fail
The card works, but I think it's not fully functional. For example, in the EAX settings menu, there's just one option to enable the CMSS 3D surround. The first time there was also other options to choose, but now it's completely blank .
There's no driver conflicts, and I have no other PCI devices installed.
In the Creative's support page for this model, I found this:
Quote :
"PCI 2.1 Support:
All Creative PCI sound cards adhere to PCI 2.1 or later specifications. This setting must be enabled for your Sound Blaster card to function properly. Note: Some BIOS's might have various options for this setting (e.g.: 2.0, 2.1, 2.2)."
My Bios have no such functions, and I don't know if it's compatible to this PCI 2.1 standart. If anyone have an idea how to find out, it would be appreciated.
And also, is there any solution for the direct sound issue ?
Thanks in advance.
Sponsored Links
Hey,
What I'd do is uninstall the drivers again, and install them manually instead of relying on the autoupdate.
Go here, and download the correct driver for your Windows version instead:
http://support.creative.com/Produc [...] nd+Blaster
You'll need:
Creative Sound Blaster audio driver 1.04.0090
+ If you have Windows Vista, the Creative Alchemy suite.
I hope doing this manually fixes the problems you are encountering, though in truth, it shouldn't be happening at all.
Reply to Gamer_Kage
Technically, I think the audigy line only supports up to EAX3 if i recall...that may be part of the problem...Still, the Directsound test should never fail...
------------------------------ http://valid.canardpc.com/cache/banner/622598.png
Reply to gamerk316
There are 960 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
