Tom's Hardware > Forum > Audio > Audio Technology > Mic problem. Gamecom 367 Plantronics headset and Realtek driver
Forum Audio : Audio Technology - Mic problem. Gamecom 367 Plantronics headset and Realtek driver
I am having my Gamecom 367 headset. It started out fine. Then it got super quiet. Now its not recording at all unless I blow really hard into the mic opening directly, and even then its really soft. I think it might be a driver problem. I have Realtek driver, and I have had some registry problems with it in the past. When I go and look at the audio output master controls it lists "rear pink port" in the volume list (which is where I have it plugged in). When I go to input master controls, I can't change the settings and it doesn't seem to be connected to the headset. The headset seems to be of a good make so I don't think that its just breaking down. Any ideas? Did I provide enough info?
EDIT: I checked it on a friends computer. Same problem. So its not the driver. So am I right in assuming that its the fault of a hardware breakdown in the mic itself?
Message edited by thedonquixotic on 09-10-2009 at 09:38:59 PM
Sponsored Links
If the mic is detachable, try inserting it directly into the port (as opposed to the headphones).
------------------------------ http://valid.canardpc.com/cache/banner/622598.png
Reply to gamerk316
Its not. I am just sending it into them for warranty. Thanks though.
Reply to thedonquixotic
There are 772 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
