G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
My home network involves three systems: desktop with XP Home, desktop with XP
Pro (Simple File Sharing turned on) and laptop with XP Home. All three are SP2
and are kept current with updates. Interconnection is through a wired router.
All three systems have been working flawlessly, but the desktops suddenly became
unable to acess the shared drive on the laptop. I get the following error
message:
"[drive] is not accessible. You might not have permission to use this network
resource. Contact the administrator of this server to find out if you have
access permission.
Not enough server storage is available to process this command."
There have been no changes to any systems involved except for XP updates since
the time everything worked properly. While I don't need to access laptop files
from another computer very often (transfer is more often TO the laptop), I'm
positive I've done it since I installed SP2.
The problem appears to be in the laptop since I connected it to a friend's
network that was set up specifically to accommodate my laptop, and his computer
couldn't see files on the laptop either. The same error message I get popped
up. His system is also SP2 and current with updates.
The laptop can see and access shared drives on all other network computers,
however. It can also access the Internet through the router. The other two
systems on my network can freely access files between themselves in both
directions with no problem.
I've checked virtual memory settings to make sure they are correct. RAM reports
OK. There are no cable problems. The Windows firewall is turned off on all
involved systems. I checked everything out with NAV turned off, but that made
no difference. Setting up the network again didn't help. I turned off sharing
and then reset it on the appropriate laptop drive just in case permissions had
become corrupted. That did no good, but I really didn't expect it to since
"Shared Docs" can't be accessed either.
Thanks for any ideas on solving this stubborn problem.
ChrisM
message:
access permission.
ChrisM
