Problems booting in safe mode
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello,
I've got a problem booting Windows XP in safe mode though it works wll in
normal mode.
I press on f8 at the begining, I do get the menu where I chose the option
"safe mode" and then it seems to boot up but after a few seconds all I get
is a black screnn and a blinking cursor on the top left (this lasts for more
then 15 mins when I get fed up and try again)
What can I do? Thanks in advance...
Bugsy
2 answers Last reply
More about problems booting safe mode
  1. Archived from groups: microsoft.public.windowsxp.general (More info?)
    You are probably selecting Safe Mode with Command Prompt.
    Use the up and down arrow keys to move the highligh to Safe Mode, when you
    see the following menu...
    Windows Advanced Options Menu
    Please select an option:
    Safe Mode
    Safe Mode with Networking
    Enable Boot Logging
    Enable VGA Mode
    Last Known Good Configuration (your most recent setting that worked)
    Directory Services Restore Mode (Windows domain controllers only)
    Debugging Mode
    Start Windows Normally
    Reboot
    Return to OS Choices Menu
    Use the up and down arrow keys to move the highligh to your choice.
    Hope this helps. Let us know.
    Wes
    MS-MVP Windows Shell/User
    In news:a7bFe.1460$q23.330090@news20.bellglobal.com,
    okopk <bugsyduck@sympatico.ca> hunted and pecked:
    > Hello,
    > normal mode.
    > more then 15 mins when I get fed up and try again)
    > Bugsy
    Wes
    In news:n3bFe.1408$q23.329679@news20.bellglobal.com,
    > Hello,
    > normal mode.
    > Bugsy
  2. Archived from groups: microsoft.public.windowsxp.general (More info?)
    A description of the Safe Mode Boot options in Windows XP
    http://support.microsoft.com/kb/315222
    regards,
    ssg MS-MVP
    okopk wrote:
    > Hello,
    > normal mode.
    > Bugsy
Safe Mode Microsoft Windows XP
